hey guys , got a few left overs from my s1 33 still sitting around that need to go.
doors with glass, good condition. LH door has 1 small dint in it $60 each
r33 s1 door cards, good condition, $50 together!
passenger side window regulator $50
MDU coilovers, 10/8 spring rates. spring height and damper adjustable. not a bad ride, i found it comfortable. $300!
sick of shit kickers, been told by 20 different people they will take them ! without ever showing up. want them gone
shimmed r33 s1 manual 4.11 LSD. locks well but nothing excessive $150
r33 bonnet, 1 small dint above drivers side headlight $60
r33 driver side front pannel $60
r33 s1 RHS headlight $60
r33 working electric mirrors, $40
17x9 +34 drifteks in black with 80%+ tread $300
180sx type x wing in black, good condition $220
monkey floor brace $60!
decat pipe, 500km old, perfect condition $50 ( selling this + driftworks pipe as ive gone full custom exhaust )
driftworks front pipe suit S chassis cars, brand new, never used $190
Located in wollongong,
sms 0416 129 811 or pm for any addition pics or info. prefer contact via mobile tho, im not on sau too often.
Cheers,
Nik
Edited by nik.
S14 LCA's, missing 1 ball joint as i was going to swap to s13 balljoints then got mine cut/extended instead so have no need for tese ( same as 33 but also have provisions for swaybar ) $130
RB25 starter motor, works perfect , $80
cusco catch can, used for 200km then blew the motor, has been sitting in the garage for 2 years. perfect condition, $50
rb25 turbo heat shield, $20
sr20 clutch slave, $20
    • Well, this, but braided line to the sender that is mounted on the chassis. Oil Pressure doesn't need to be close, while I prefer Oil Temp is in the active oil flow (bro science, not sure how much it matters).  That's how I've had mine set up for years and it works OK
    • Welcome back! There is a v series forum, a little quiet at times but every new active member helps
    • But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
