Got a set of sard 550cc injectors out of me 33 have gone bigger injectors for e85 so no need for these were working fine car was making 306rwkw no rail included but comes with rb25 loom with plugs to suit sards. Have been flow and tested after been taken out just for my peice of mind and buyers. Asking $600 for injectors and loom. Msg or call me on 0433167726 cheers jade
https://www.sau.com.au/forums/topic/419847-550-sards/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
