both for sale as going in a different direction. both are in great condition...
safc allows for a tuning of you air flow, and SITC allows your tuner to correct timing. the sitc are getting very rare now....
perfect for autos, or any standard car. will see a great power gain over stock.
safc 2 $250 nego.
https://www.sau.com.au/forums/topic/420190-apexi-safc-2-and-apexi-sitc/
  • Replies 40
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
