Im considering to sell my current turbo setup as im going a full forged rebuild and want to push more power and go single turbo
The setup consists of:
* Trust/Greddy T517z 10cm twin turbos which were rebuilt 10,000kms ago with Genuine Mitsubishi Industries rebuild kit
* Trust/Greddy oil lines and returns
* HPI 3" stainless steel bell-mouth dump pipes (heat wrapped)
* Exhaust Manifolds + heat shields
*Twin Turbo pipe which has been modified with the diversion plate to rid shuffle
*HKS hard pipe from twin turbo pipe to guard
*Stock RB26 rubber intake pipes
this is a complete bolt on package, nothing else to change or modify, i made 370rwkw with these turbos on a totaly stock engine last week
very capable 400+kw setup
i have run an 11.30 1/4mile time @ 127.5mph at 340rwkw
asking around $2800, like i said im not desperate to sell, if it doesnt these are going back on my engine
Located in Sydney
Edited by SiR_RB
Forgot to add comes with custom made twin 3" into 3.5" merge front pipes (heat wrapped)
Sorry guys not separating anything unless the turbos are sold off first
pics as promised:
divided twin turbo pipe + HKS hard pipe + intake pipes
custom twin 3" into 3.5" front pipe (heat wrapped)
Trust Greddy T517z 10cm complete with HPI 3" dumps, lines etc
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
