Ok so i wanted to change my dash from that pale yellow to a nice white colour to match my boost gauge and just look nicer. I bought white leds and put them in etc. When i lit it up it is actually a bright-ish blue (see pic). I took out the leds and made sure they infact light up white which they do. So i pulled the cluster apart and noticed the faces have a blue coating on the back. Is there an easy way of removing it? or has anyone ran into this problem before? Seems strange that the OEM bulbs had blue rubber things on them, the dash face was blue yet it lights up that pale yellow?
I have heard about the same thing on subarus except green. Has anyone come across this before?
pic
https://www.sau.com.au/forums/topic/421110-r33-dash-cluster-colour-change/
I could be wrong, but it sounds to me that the LED's are colour-filmed so if you look at your picture, the dispursement of light is more bluer in some parts but not all. I suggest you buy new LED's and try again - no they should not have any blue film on them at all as the glass globe itself should be the colour you chosen. I personally have BLUE LED's on mine and they look great and have last over 2 years now.
Yeah thats what i thought but i took them out and tested them and they definitely are white, atleast alot more white than what shows.
If that's the case then it's your desh...maybe someone painted them blue from the inside? Give them a clean and try again...
i have gone through this problem. I bought one set of cheap led's (supposed white) and they lit up pale blue. Then I went and splurged on more expensive leds from aus. Boom stark white. The second set I bought are those 9 led ones.
Is yours a single big led?
THIS
Instead of THIS
$%28KGrHqJ,!n4E9c-jnUi4BPhbE+0jT!~~60_35
Mines exactly the same, was looking for a clean crisp white but ended up with a slightly bluey purple. It looks like the only way to change it would be to change the face of the gauges I guess. My originals also had the blue caps on them.
Yeah mate i do have those 9LED lights, i took them out and in the dark checked them in a number plate light holder, and they are very white. Atleast ALOT whiter than they show in the dash, the seller which sent me the leds sent me another batch which should've been slightly whiter, and they look a little less blue... Not sure what to do haha maybe white just aint going to happen. Thanks for help so far though guys.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
