Hi Guys, I have a R33 GTR, I suspect the fuel pump to be faulty.
I've read the tutorial abt Bosch change overs and gained a lot of info, I.m not experienced with modern fuel systems, more of your carby type
I wanted to check that the pump had power before I started to pull it all apart, there is at the fuse but which conector is for the pump, the gray or the brown, I'm guessing it's the brown as it only has two terminals
There is no voltage there with the ignition turned on, assume there should be or is there something deeper????
Wuold appreciate any info
Cheers
Terry
https://www.sau.com.au/forums/topic/421387-dud-fuel-pump/
