Hi all ! how are we?
Im new to this site so first topic post!
I have a 1994 R33 Nissan Skyline Gts-t manual with usual mods, boost controller, Front mount,exhaust, pod, fuel pump and fuel Pressur Reg and Clutch, I recently put a garrat GT3076R high flow in and its very awesome! runnign 12 psi she sings. but planning to get an ECu put in and tuned so i can run more boost with safer levels as now the ECU doesnt quiet adapt to the higher boost :( haha
my question is , before with the Stock Turbo, when i would wind the boost up to 12 psi it you's to R/R (Rich and Retard) and cut but now when i wind it up i can go to 15 psi if i want and it will take it ! and wont R/R just wondering if there is some sort of Mathimatics going on there with the air flow? my boost controller is of the Throttle body so it reading is Correct....
its a spinny one has had me thinking about it for a while! could it be that it isnt actualy getting the correct amount of boost? in order for it to R/R.
I went throught the trouble of putting the older turbo back on to test and bam! 11.5 PSI R/R !! put the bigger flowing turbo on more power at same PSI with no R/R at all.
Its not a major issue, i would like to know if it could be doing harm? amd should i be worried? and if you have the correct answer to this?
Thanks!!
https://www.sau.com.au/forums/topic/421442-r33-gts-t-boost/
Rich and retard works off loads at different points of the rev range. So the point in the rev range that was triggering the rich and retard is probably getting lower airflow with the bigger turbo. This means it was probably lower in the rev range. The stock turbo comes on boost by under 3000rpm. Your new turbo won't be making as much airflow at lower rpm.
https://www.sau.com.au/forums/topic/421442-r33-gts-t-boost/#findComment-6779575
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
