Driving Around With A Leaking Exhaust Manifold Cause Any Damage Apart From Sounding Horrible
Gday,
I have a leaking manifold due to one of the holes were the studs screw in being threaded and not having a stud in there. It never was a problem for about 9 months but now i believe it has warped the manifold from the heat unfortunately and in turn completely ruined the gasket for the last cylinder. At first it was just a tick tick tick when cold now everytime i downshift or let off the throttle you can hear loud backfires from the motor escaping the manifold and a bit of a sucking noise under boost. I know this isnt ideal to drive with due to it sounding like a tractor but the manifold gasket and studs have been purchased and im just waiting to buy a new front pipe and decat to do all my exhaust gear at once.
So as the topic states does driving around like this cause any problems e.g bad for valves. I know it takes longer for turbo to spool up, cant hold boost for as long, sounds terrible etc but more worried about the motor as this is my daily driver. I would of thought it would ruin economy but it has probably been better as i have been rarely hitting boost. Its a rb25det btw with a stock turbo and internals. Within a week or two it will be fixed but i rely alot on my car and time is always short. ANy input will be greatly appreciated
Without having heard it myself, I would be on the cautious side and say nurse it as much as possible. Aside from the carbon monoxide rolling into your cabin, the leaky manifold increases bay heat much quicker, and can eventually cause some valve damage. Best avoided if possible. Also, rarely hitting boost doesn't necessarily equate to better economy, since, if it's struggling to hit the higher RPM range, it offsets the lack of air with a bit more fuel. Just a thought.
rarely hitting boost will generally mean better economy, but not in the case of a leaking exhaust. in normal cases, using lighter amounts of throttle means less boost, which means better economy for 2 reasons. 1: less air going into the system, so less fuel is required, and 2: lower throttle percentages means the ecu is reading in lower load cells, so it will generally stay in closed loop (using o2 sensor feedback) and be running on leaner AFRs.
but in the case of an exhaust leak, you will have less efficient exhaust flow, and you will be using more throttle (so higher load values) to go anywhere, so while the boost levels may be lower, you would be using more fuel than if you were to have no leaks and be driving around at the same boost levels (which would mean less throttle than you currently are).
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
