Nsw: Huge Workshop Cleanout Rb20/1Jz Engines, R154, Rb20 Boxes, Td05 Turbo, Splitfires,niztune,inj,r32/33 Knuckles, Coilovers, Twin Plate Etc
JZA70 1jz + r154 Complete motor package for sale. recoed head with genuine parts head gasket timing belt etc, 2jz water pump conversion, pully kit, custom dump pipes, ecu harness etc, everything to do a conversion $3500 ono
2X RB20 engines both in good running condition, both come with inlet manifold stock injectors, cas, both near new heavy duty clutches fly wheel, engine harness, igniters, No turbos on both $850ono each engine
2x RB20 boxes 1 of them is good has typical rb bearing noise (not bad noise) $450 ono and the other box works but noisey on decel when in 1st and 2nd $300ono
RB 20/26/25series1 splitfire coilpacks with harness near new $380 ono
RB Stock coils with harness $100
Rb20 niztune, only done 1 track day since new $450
Z32 afm with modified plug to plug in rb20 stock afm plug $150
siemens top feed 610cc injectors only 1 track day old $450 ono come of my rb20
Kinugawa TD05 turbo setup with rear housing modified to run 45m or 44mm turbosmart tail gate, (selling gate separate) turbo set up comes with all the braided lines and fitting to go in block, dump/front pipe, front intercooler pipe, inducer pipe, turbo is 1 track day old made 222rwkw on 22psi $800ono was on my rb20 r32
Turbosmart 45mm gate with screamer 1 track day old $495
RB26/25 exedy twin plate plenty of meat left done hand full of track days since new $850 ono
RB26 complete polished inlet manifold TB's all fittings are dash fittings modified, water neck is modded, was in my rb26 180sx $450 ono
Garage 7 r32/r33 extra lock knuckels with hubs extended lca's brand new tie rods and tie rods spacers (my 32 has so much lock with them that if i go full lock dump the clutch to do donuts, the car will just crab walk loland theres no bind $750ono
G4 coilovers to suit r32 $500 ono
gktech rear camber arm to suit r32 s13 near new $180ono
2x hicas lock bars off my r32 $80 each
r32 front strut brace $50
Gizmo electronic boost control $180
apexi pod filter $50
r32 adjustable caster rods $50
r32 gtst front calipers and discs new qfm A1rs pads and machined discs $350ono
r32 rear 5stud hub discs calipers with new qfm pads$350ono
gtr drivers seat in average cond no tears $250
r34 gtr recoed rear drive shafts (new) $400ono for the pair
deauschworks fuel pump (300L e85 compatable), 1 track day old $150 ono
Rb trust oil cooler and sandwich plate with lines $350 ono
intercooler kit to suit rb20 r32 4350 ono near new
ca alloy radiator $100
2x spal 12inch puller fans (1200 cfm each) near new $250 for both
16 inch spal high preformance puller thermo fan 3000cfm near new $280 ono
aristo hks coilovers $800 near new
brand new pbm hydro hand brake with handle grip and line kit $300
sr20 igniters $50 each
r33 widebody front gaurds 20mm $250
saas gauges with cup holders, oil/water temp, oil press, boost with sensors not old $150 for the lot
i can sms pics if your interested, please no tyre kickers as i have a workshop to run, all parts in castle hill call pete 0407008651
Kinugawa TD05-18g turbo set up to suit stock Rb20 manifold, turbo and turbosmart hypergate 45mm are 1 track day old, all new braided lines, front cooler pipe, dump/front pipe, inducer pipe made 222rwkw 22psi Will sell the lot for $1150 or turbo setup less gate for $800 and wastegate for $450
  • 2 months later...
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
