nissan s13 part out let me know what yous need
engine ca18det with new acl metal head gasket
compression test was done and got 150 psi though all 4 cylinders here some parts
all panels available car is complete here are some parts
after market radiator with new hoses
intercooler
apexi pod filter
z32 air flow meter
gtr 444cc injectors
modified intake manifold with r32 tb
t28 turbo
boost controller
after market fuel pressure regulator
split fire coil packs
oil catch can
manual gear box with new clucth
blitz bov
3" exhaust front pipe with high flow cat stainless steel modified to fit the sr20 t28 turbo
engine damper
gktech metal bash plate
lsd diff
nistune ecu
exterior
*after market corner lights and front bar indecaters
*aftermarket alteza rear lights
*drift teks 17*8 all round
triple projector headlights
silvia grill
interior
*gtr front seats
*180sx door trims and glove box with factory option cool box
*type x rear seat
*digital climate control
digital speedo with hud display had it reconditioned
type x leather stitch steering wheel
silvia factory option floor mats
suspension and brakes
bm44 master
cusco coilovers
front stut brace
controll arm brace
fender bracing
in cabon floor brace
diff brace
white line rear sway bar
s15 front calipers pads recently changed slotted front rottors rear brakes have new pads and cross drilled slotted rotors
call or text me if interested 0432-062-780
will let you know the prices located in melbourne
hey mate would you sell the starter motor?
would you know if the cluster would work with any ca18det, as mine isn't digital?
Edited by Beau.r
  • 1 month later...
  • 1 month later...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
