R33 S1 & S2 Parts
11 December 2012 - 04:05 PM
Found all these parts laying around the garage and thought i might as well sell them since i cant use them and wont come handy if i get defected and need to go back to OEM for the inspection. I'm located in QLD Gold Coast if anyone interested msg me on 0422660086 Sam can post at buyers expense.
R33
S2 Front bar inserts (both) $100
S2 Stock ECU $ 100
S2 Gearbox mount $50
Air Con (complete Unit) $150
Fuel Rail & injectors $150
Throttle body (complete) $50
Clock $25
S1 Ignitor Pack and coilpack leads $100
S1 Splitfire (near new) $400
Washer bottle (no lid or motors) $20
Walbro Fuel pump 341 $50
Walbro Fuel pump 342 $80
Walbro Fuel pump 342 (NEW IN BOX) $150
Stock fuel pump (jecs) and intank mount $100
S2 Airflow meter and Pod Filter $150
Large Taco Gauge $100
S2 Spoiler (White) $ 80
GTR Spoiler (Purple) $100
S2 Front Bar Reo $100
S2 Tapper cover Breathers (NEW) $40
S2 Front Seats (both) $100
Intake Manifold $50
Clutch Fan X 2 $20 Each
S1 Grille $25
Variety of silicone hoses mainly 2 - 2.5 inch $20 each
T3/04 china turbo used still works $100
gif.gif DSC00010.JPG 147.37K 3 downloads
gif.gif DSC00011.JPG 148.63K 2 downloadsgif.gif DSC00013.JPG 133.4K 2 downloadsgif.gif DSC00014.JPG 144.62K 2 downloadsgif.gif DSC00015.JPG 147.56K 0 downloadsgif.gifDSC00016.JPG 151.2K 0 downloadsgif.gif DSC00018.JPG 138.75K 0 downloadsgif.gif DSC00019.JPG 146.17K 0 downloadsgif.gif DSC00020.JPG 141.17K 3 downloadsgif.gifDSC00023.JPG 147.21K 4 downloadsgif.gif DSC00021.JPG 148.56K 0 downloadsgif.gif DSC00022.JPG 138.59K 1 downloadsgif.gif DSC00024.JPG 143.95K 0 downloadsgif.gifDSC00025.JPG 138.5K 1 downloadsgif.gif DSC00026.JPG 140.4K 1 downloadsgif.gif DSC00027.JPG 152.69K 0 downloadsgif.gif DSC00028.JPG 132.38K 0 downloadsgif.gifDSC00029.JPG 141.44K 1 downloadsgif.gif DSC00032.JPG 142.58K 0 downloadsgif.gif DSC00030.JPG 149.15K 1 downloadsgif.gif DSC00031.JPG 143.2K 0 downloadsgif.gifDSC00033.JPG 133.31K 0 downloadsgif.gif DSC00034.JPG 133.76K 1 downloadsgif.gif DSC00035.JPG 141.2K 1 downloadsgif.gif DSC00036.JPG 135.14K 1 downloadsgif.gifDSC00037.JPG 146.81K 1 downloadsgif.gif DSC00038.JPG 131.83K 6 downloads
https://www.sau.com.au/forums/topic/423446-r33-s1-s2-patrts-galor-must-go/
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
