2003 MY04 79V Subaru Forester XT
Price $14,500 ono
Colour: Champaign (Gold)
Interior Colour Black
Transmission 4 speed sport Auto
Body: 4 door 5 seat plus back cabin space
Drive Type 4x4
Engine: 4 cylinder Premium Unleaded Turbo Intercooled 2.5 L
Reg Expiry Mid July 2013
Road worthy Yes
Kilometres: 100,632
Brief Comments: Extremely good condition both inside and out, always garaged. Very low kilometers, at least 50,000km’s less than any other 2003 or 2004’s on the market. Slightly Modified but never thrashed or boosted– See list of modifications below for details. I have owned this car since 2008, bought it with about 92,000 km's on it.
There are some VERY minor hail dents on the bonnet (4 or 5 total on the entire car) from a hail storm in Perth.
Car has always been serviced, next due for service at 103,000km’s.
Aftermarket modifications include:
  • 3” X-Force turbo back exhaust with twin tip oval muffler
  • STi top mount inter cooler and BOV (off a Spec-C rally car)
  • Samco silicon hose bits
  • Pedder’s Sports Ryder suspension
  • 22mm Whiteline rear sway bar
  • Front strut brace
  • Turbo beanie
  • Hypertech cold air intake (in guard pod filter)
  • Pete Mac blanking plate
  • 18 x 8 Apec Inspiri wheels
Reason for sale: This car is no longer being driven as my R33 GTR has become my daily driver. The Forester has been sitting garaged and not driven for over a year so it is now time to sell it.
The following pictures were taken when we lived in Queensland, I will take some recent pictures in the next couple of days.
However the car is in the same condition as it has barely been driven. When we were in Queensland for example it was in a secure lockup garage as we worked on an island and only got across to the mainland on occasion.
Edited by Deziner
https://www.sau.com.au/forums/topic/423505-2003-my04-subaru-forester-xt/
I sold my SG9 XT for $13,500 and that had 201,000Kms. So this should go with your discounted price and half the Kms.
One of our OzFoz Members has upgraded his > 283awKw without much fuss :)
Yes, his OzFoz User Name is "PCXT".
Had lunch with him 2 weeks ago - discussing OzFoz Tech Nights
I'll try and find a link to his build after I get this damn court report finished. I hate doing them but worth $880 (with zero outlay).
Your XT has the metal air pump.
Mine had a plastic one that permitted leakage of air into cylinder 1 and maybe 2 leading to corrosion if not rectified quickly. It would throw those two codes and impair cruise control.
So your XT never had that problem.
And by 2008, Subaru had gone back to a metal pump.
I have had the P (something) code for manifold 02 sensor. I played around with the 02 sensor wire and it went away.
Was told to reflash to ECU rather than replace the 02 sensor, hence why I was considering the reflash, so it doesn't come back!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
