Wanted to keep these but can't hang onto these parts and not use them.
These are V8 Supercar Alcons control calipers, front pair only. Those who know are aware that these are some of the best calipers money can buy, forged monoblock design they are very strong and very light. You can't help but smile every time you look at them.
Will accept a Ø380mm x 36mm thick rotor and 25mm thick pads. They have the typical cosmetic scratches but that is to be expected with used parts such as these; they do not need a rebuild they are in perfect servicable condition.
Price is $2k firm for SAU members. Can post at buyer expense, contact via phone preferred.
Thanks, Mike
0407 801 338
https://www.sau.com.au/forums/topic/423517-v8-supercar-alcons-front-pair-2k/
what size wheel did you have on your car?
I have TE37SL but they will fit under Enkei RPF1 in 18x10.5 with GTR offset, they can be had cheap from traders on the forum.
Not sure what other wheels would work, there would surely be others.
Hey Mike, whoever bought these, would they like a set of four pot rears that would match up nicely with these? I have a spare set that im willing to part with.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
