Update
Wheels are sold, drivers window switch sold.
Price drop - Coilpacks $50, Wastegate $50.
Also have 2.5" exhaust with xforce cannon including cat. $200 pics to come soon.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
