Hey there! Selling some items as I am upgrading. All items in good working order, located in Campbelltown, Sydney.
Apexi Power FC with hand controller - came out of my series 2 gtst - $950ono
Apexi AVC-R - comes with everything - $300 ono
Nismo 740cc injectors - $600ono
Z32 afm with plug - has both mesh screens pulled out - $200ono
Walbro in-tank fuel pump - $75
Think that's it. Will do a deal if someone wants to buy several items. Thanks
https://www.sau.com.au/forums/topic/423728-rb25r33-parts-pfc-injectors-etc/
Make an offer on silver avcr and genuine z32 with plug. Also have .63 internal gate gt30 5 bolt rear housing lying around, $250. Dump/front pipe with screamer 5 bolt flange 250 ono. Custom forward facing plenum mounted on stock runners, bellmouth tubes inside $350 ono.
Just to add to the JJR part, I still have the cross over pipe to suit standard plenum as well. Either way $220 ono and i'll chuck in whatever pipes I got around here lol
  • 1 month later...
  • 1 month later...
  • 1 month later...
Still have stainless dump/front pipe to suit internal gate gt30 (5 bolt) $280. Also have dump/front pipe with screamer to suit stock turbo (6 bolt) $250. Aaand .63 internal gate gt30 rear housing with actuator $250, stainless intake pipe with fitting for bov or catch can $100.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
