hey fellas, I bought this chain and ABUS padlocks from a Sydney locksmith last november to secure my boat trailer to a electricity pole outside my house.
boat's now been sold and iv'e relocated to melbourne so PICKUP ONLY on this item due to weight (Box Hill South, Vic).
It's a 10ft / 3m hardened steel chain made specifically for securing motorcycles, trailers and such. Also 2 ABUS padlocks (one bigger to fit the chain and one smaller).
The chain uses 13mm hardened steel links and is fully jacketed. The ABUS padlocks each had a security cylinder installed with registered/secure key ie. the padlocks cannot be picked or bumped.
Neither the chain nor the padlocks can be cut with bolt cutters, you'd need an angle grinder and plenty of time to cut through the 13mm links (even longer on the padlocks). Only one registered key but 2nd can be provided by ordering from locksmith who has the code ($40 from memory).
I paid $350 for the chain (was on sale) and $100 for the bigger ABUS padlock and $80 for the slightly smaller. Then $100 for each padlock to have the security cylinders installed (can't be picked or bumped) so a bit over $700
Perfect for securing a motorcycle, trailer and maybe even a car. I used this to secure my boat trailer as it had to be parked on a busy street and almost got stolen on day 1.
Asking for $500 or best offer.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
