Man whats with the "ring nissan"?? Half the nissan dealers dont even deal with import parts u fool!!!!
like are u serious?
if you feel that strongly about ringing nissan then go do it yourself man but we have some decent people here who are willing to share their knowledge and experience regarding our cars!!
If you diont like the thread then dont bother posting!
its so simple......!
yeh, ive been looking around at how much this will cost, and one place is offering a timming belt change with all genuine nissan parts, oil change, oil filter change, ngk platnim plugs and...i think thats it, all for around the $700 mark.does this seem a little steep or is that the going rate, also y the spark plug change? andoil and stuff, cant they just do the belt and charge me for the labour...lol, wats the belt cost like $100 or sumthin?
well, your wrong. most nissan dealerships stock parts for imports now, they have realised the market. and i dont know where else to get a genuine belt. so ring nissan for the latest price on a genuine cam belt. lol.
genuine gt-r cam belt = $90
idler, use nissan genuine only = $250+
tensioner, use an RB30 one = $90
install, labour for mechanic around 3 hours = $130
enough for ya?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
