Up for sale is my 1995 Toyota Supra SZ turbo. I've only had it for a little while and although I absolutely love it, I'm finding it a little impractical when the main family car is out and so I need to get into a car with more room in the rear.
The previous owner took ownership of the Supra from his mother who was the first owner since it came into the country over 10 years. He has spent thousands and thousands in improving the car and I have been given almost "every" receipt and history documentation for the car....two folders full of receipts!!
Some details of the car are below
Colour: Silver
Odo: 167,500
Engine: 2jz-ge turbo
Trans: 5 speed manual
Rego: Feb 2013
Price: $14,500 ono
Modifications
Engine
-2JZ-GTE Metal headgasket
-Greddy E-Manage Ultimate ECU
-Custom air/oil seperator
-Custom ETS (Extreme Turbo Systems) turbo kit
-Precision 6262 ceramic ball bearing with .63AR Ext (Ceramic coated)
-Tial 44mm Wastegate (Ceramic coated)
-Extensive heat shielding
-Exhaust manifold and down pipe with flex joint all ceramic coated
-Intercooler outlet pipe to inlet manifold ceramic coated
-GFB Boost controller
-Titan Cam gears
-Recirculated BOV
-5Zigen ProRacer Exhaust Quiet but aggressive sound without drone
-Front Pipe with Magnaflow Metalcat (ceramic coated)
-Larger injectors (might be 600cc plus)
-Bosch Fuel pump
-Engine oil cooler
-Golpher 52mm alloy radiator
-Tuned at Silver Water Automotive Services making 260RWKW @ 13psi (will easily make more at higher boost)
-Fuel Economy: 650-700KM to a tank Highway and 500-550KM daily drive traffic.
Drivetrain
-Fidanza Aluminium Flywheel
-Clutch Industries ceramic clutch (brand new!!!)
-KAAZ 2-Way Limited Slip Differential (professionally detuned so no clunk at all - can)
-Redline Gearbox oil with Moly added
Suspension
-KW Varient 3 (German suspension, price $3500 installed)
-Power steering oil cooler
Brakes
-Wilwood 4 piston calipers all round with braided lines
-334mm DBA slotted discs Front
-323mm Slotted discs rear
-Motul RBF440 brake fluid
Wheels/Tyres
-17x10 Lightweight 949 Racing wheels
-255/40/17 Dunlop Direzza Z1 Star Spec
Interior
-Velo Racing Seat
-Schroth Racing 4 Point harness
-Clarion head unit
-Alpine amp
-Kicker slimline sub
Other
-Overhauled air con system recently installed and gassed
-Air/con condenser thermo fan fitted.
-Car was completely resprayed in original colour by reputable workshop in Ryde under insurance few years back (Have receipts to show)
Although not a factory RZ twin turbo, it definitely goes, handles and stops far better than many out there would and without the bigger price tag. We all know how good the 2JZ-GE motor is and if turbo charged correctly, they are awesome and run all day without an issue, but if something did go wrong, then a replacement used motor could be had at a fraction of the cost of the GTE engine. Apart from the thousands spent in mods, this was what attracted me to this setup.
This car could also be an option for P Platers who cant drive turbo cars...just remove the turbo kit, get a set of extractors, bolt them to the exhaust, re-tune and drive it. Once you're off you P's, bolt the turbo kit back on :)
The car is mechanically perfect so there is absolutely nothing to spend there. Cosmetically, there is one dent on the passenger door and a few scraps on the front bumper bar but that's about it. I am happy for any inspection to be carried out at the potential buyers expense.
Feel free to pm or call me on 0407 931 097.
post-6485-0-42961500-1370841188_thumb.jpg post-6485-0-74403300-1370841257_thumb.jpg post-6485-0-78135600-1370841318_thumb.jpg
post-6485-0-29183600-1370841376_thumb.jpg post-6485-0-42537500-1370841436_thumb.jpg post-6485-0-76927500-1370841506_thumb.jpg
post-6485-0-26648900-1370841563_thumb.jpg post-6485-0-55210400-1370841634_thumb.jpg
https://www.sau.com.au/forums/topic/426744-nsw-1995-toyota-supra-turbo/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
