HKS Superdragger SR JASMA
3" Inlet, 6.5" Muffler, 4.5" Tip.
Includes Tip, Muffler, back to Mandrel Bend, Flange plate. Great for top end power.
Good condition, recently polished and coated.
$220 Neg.
Contact James at [email protected] or 0401 348 776
Owww ok, its just that i took it to Powerplay Imports and they rekoned it was a Superdragger. Afterlooking at the HKS web site, it looks like a Superdragger II to me, Yes, its def not the original model, but looks like the II model. I've never seen the Hyper model on their web site, but yes, it does look like it.
is not a super dragger 2 either cause the muffler is rounded like the original.
this is clearly the hyper muffler.
anyway is not suitable for nissans cause the piping bends the wrong way. suitable for cars with mufflers on the right side of the car.
out
This was taken straight off my r33 gtst. so yeh, fits skylines no probs... Minimal bends for maximum flow. You can make it fit whateva you want it to fit, you would cut off the current pipe and weld the muffler to what you already have.
I use a twin tip now, thats why im selling.
