This car has done 145kms and is a unique 4 door
The car has the following mods:
-Plazmaman intake manifold (fitted by Shift performance have receipts spent around 2k)
-Black front mount intercooler
-HKS EVCS boost controller
-Pro sport boost, fuel pressure and exhaust temp gauges
-tomei blow off valve plumed back
-2 and a half inch car back exhaust
-ID1000 injectors
-HKS airnex intake kit
-silicon turbo inlet
-Nustune ECU tuned by Unigroup (over 2.5k spent on tune to make 205rwk have receipts)
-slotted rotors
-brand new battery
-4 new tyres fitted today
-Walbro fuel pump 255LPH GSS242 fitted
-R34 GTR dash fitted
Recently been serviced, new oil and oil filter new gearbox oil 6 months fresh rego. Immaculate interior non-smokers car. Will suit fussy buyers
Contact Alex on 0430 083 275
https://www.sau.com.au/forums/topic/427045-r34gtt-2000-for-sale-14500/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
