Hi everyone, the missus reversed our stagea into something and insurance company has written it off,
Its a 2000 model RS4 Dayz. Overall car is excellent with the only damaged parts being the rear bar and both left hand doors. Engine not available as i got this wicked idea of fitting it into a Patrol :) Full black leather interior, electric seats with heating function, Carbon fibre exterior trims and rear view mirrors.
Parts located in Ballarat, Victoria, inbox for parts requests or post up here..... Who car, minus engine available for purchase for $4000obo.
Stay tuned for a list of parts and prices as we are currenty trying to work out what thins are worth.
Edited by RSFOURDayz
Hey mate, couple of inquiries:
How much for side strips?
How much for center console leather trimmed lid? (the one between the seats.)
What carbon trims does it have apart from the cargo window garnish? I may be interested in some or all of them, so post prices.
I work remotely and have trouble pm'ing for some reason whilst I'm away so feel free to SMS me on
ofour 2three 9.fourseven 4two4
Harts.
OK SOME PRICES ON MAIN STUFFS
Front Dayz Bar - excellent - $450
Front Reo $120
Tiptronic Auto - excellent condition $500
Bonnet - excellent conidtion $450
Rear tail lights - $60 on t/gate - RH corner light $80
Door mirror l n r with carbon cover $100
Full leather interior, electric controls and heating $600
Main headlights, xenon - $200 each
Grille Lights - $80 each
Grille - XC - $150
Main window switch $80
Combo switch $60
Rear Dayz Wing $180
your carpets, do they have stagea badges on them? if so, pics and price possible please?
the carpet ,ates do yes, but not th actual car carpet
how much for the wheels - ive got a s1 stag and a dent in the front wheel that wont pass RWC
im in vic so nice and easy to collect from you asap :)
cheers
Pete
Unsure on compression ratio at the minute but its done 140,000, runs very well, no problems with coil packs or anything like that. Chasing 2,000 for complete engine
He peeps... Just a heads up to anyone in Melbourne, we are heading to Bulla for the day in the northern suburbs so if anyone wants anything brought to Melbourme let me before Friday night. Cheers
SOLD SO FAR......
INTERIOR,
WHEELS,
CARBON MIRRORS, CARBON TRIMS,
LH TAILGATE LIGHT
LOCK SET AND ETAX MODULE
STRUT BRACE
STILL MANY PARTS LEFT
  • 3 weeks later...
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
