In case Pioneer have changed their connections at some stage, it's to suit a DEH P4350 head unit.
I actually want a stacker output to RCA input cable. If I can't find one, I am hoping I will be able to make one using a CD stacker connector cord thingo.
i have some random cable for a stacker in my car now...not using it, not sure what it suits but doesnt plug into my kenwood headset thats for sure. I will try and gert some pics of it and send them your way before the weekend is over.
haro
