does a larger spark plug gap (as large as possible), necessarily equate to more power (noticeable power).
We close our spark gaps to compensate for any extra boost, but are we effecting our car's power/effiency in other ways by doing this...(3 steps forward, 2 steps back???).
Would it really be that nice if we could all get a set of Splitfire Coils Packs and run massive GAPS ?? (would we actually 'feel' the difference...I'm not interested in Dyno results that show a .0009% diff).
Is that why there are such things as Splitfire's etc....because those in the 'know' realise that there are 'real' power advantages to be gained here.
Or is this just another 'Peter Brock Crystal Polariser' thing.
Keep in mind that my Skline, and probably yours, is a daily driver.
Thankyou, I look forward to your thought!!
Mark
the coils have to be upgraded to support the spark to make the gap to ignite the fuel to push your skyline into the horizon. Those coil packs are a neccesity when upgrading your turbo so that you can make a strong enough spark. The larger the gap the more power you should get until you gap it too much and you start to lose power because there is no spark.
Please correct me if im wrong.
thanx again Croatian.
Spit.
Larger gap and I notice a drop in power. Almost like a hessitation higher in the rev range.
I have to gap mine to around .75-.80 minimum. Thats running up to around 16-17psi of boost.
Hey Joel, what mods have you done to your engine internals to make it handle that boost. Don't tell me about the outboard stuff that made you get the extra boost, please tell me if you've had to do any engine 'strengthening" (?)
I'm currently reading 10 spike 11 on my speco, with a totally stock motor.....do you reckon that's safe.?
Thanx Mate.
Its an RB20DET that runs 16-17psi.. they have a lower static comp so they handle more boost without having to fiddle with the ecu.
+ its got an external pump fitted so it runs rich which keeps the combustion temps down and helps keep the ceramic exhaust wheel cool.
No doubt if it hit the track the turbo would let go.
Depends on the tuner if the boost is safe or not. :rant:
On the stocker ecu you tend to get power dips over 11psi anyway.
well explained Joel, makes sense (lower compression motor can handle more boost!!)
"Depends on the tuner if the boost is safe or not. :)".....am I the 'tuner'.
are you saying that it depends on common sense, constantly listening to the workings of the car and noting anything 'out of place' will keep Skline happy....and did I mention COMMON SENSE?
thanx man 4 ur quick response!!
mark.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
