Who has actually put a GTR gear set into an RB25det gearbox?
Other than swapping front and rear housing... what is needed???
I know it's done, just need absolute details.
Cheers
Justin
PS I've been searching for a while, just can't find any specific info.
Edited by XRATED
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
