Power FC and hand controller suit r34 gtt rb25det neo
$900
A.r.e oil cooler set up made for r33 gtst for where the grill is
Comes with everything great condition coolest thing ever only so many ever made
$600
A.r.e radiator set up to suit r33 comes with all the hoses, radiator, bottles, fitting, fan etc
$500
A.r.e custom water washer bottle
$150
A.r.e custom oil catch can
$100
A.r.e custom power steer reservoir
$100
Garrett gt3082r set up suit rb25
Turbo Had a new core out in not to long ago have receipt
Stainless manifold
38mm wastegate with screamer
Intercooler return flow with custom stainless piping
Turbosmart bov
Custom stainless intake pipe
Dump and front pipe
All braided oil and water lines etc comes with everything
$1800
R33 r34 manual conversion complete
Comes with a r34 gtt gearbox comes with everything needed
Button clutch
Fits both r34 r33 came out of a r33
$1400
Gizmo electronic boost controller
$100
Splitfire coilpacks to suit rb25 neo
$380
Power interprise 660cc injectors suit rb25det neo
$450
Rb25de neo complete motor comes with loom and Ecu great condition
$700
R33 nismo front strut brace with bmc stopper
$150
R33 nismo rear strut brace very rare
$130
R33 cat back exhaust jasma 3.75 inch mild steel
$180
Z32 afm with plug $130
Have many other parts available
Gold Coast
0487924497
post-50709-0-10335300-1375789640_thumb.jpgpost-50709-0-97100600-1375789729_thumb.jpgpost-50709-0-74521700-1375789806_thumb.jpgpost-50709-0-54391000-1375789985_thumb.jpgpost-50709-0-56943300-1375790026_thumb.jpgpost-50709-0-70582500-1375790039_thumb.jpgpost-50709-0-07135200-1375790053_thumb.jpgpost-50709-0-21174600-1375790067_thumb.jpgpost-50709-0-97678000-1375790102_thumb.jpgpost-50709-0-52597200-1375790140_thumb.jpgpost-50709-0-19187000-1375790173_thumb.jpgpost-50709-0-88342900-1375790209_thumb.jpg
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
