Power FC and hand controller suit r34 gtt rb25det neo
$900
A.r.e oil cooler set up made for r33 gtst for where the grill is
Comes with everything great condition coolest thing ever only so many ever made
$600
A.r.e radiator set up to suit r33 comes with all the hoses, radiator, bottles, fitting, fan etc
$500
A.r.e custom water washer bottle
$150
A.r.e custom oil catch can
$100
A.r.e custom power steer reservoir
$100
Garrett gt3082r set up suit rb25
Turbo Had a new core out in not to long ago have receipt
Stainless manifold
38mm wastegate with screamer
Intercooler return flow with custom stainless piping
Turbosmart bov
Custom stainless intake pipe
Dump and front pipe
All braided oil and water lines etc comes with everything
$1800
R33 r34 manual conversion complete
Comes with a r34 gtt gearbox comes with everything needed
Button clutch
Fits both r34 r33 came out of a r33
$1400
Gizmo electronic boost controller
$100
Splitfire coilpacks to suit rb25 neo
$380
Power interprise 660cc injectors suit rb25det neo
$450
Rb25de neo complete motor comes with loom and Ecu great condition
$700
R33 nismo front strut brace with bmc stopper
$150
R33 nismo rear strut brace very rare
$130
R33 cat back exhaust jasma 3.75 inch mild steel
$180
Z32 afm with plug $130
Have many other parts available
Gold Coast
0487924497
post-50709-0-10335300-1375789640_thumb.jpgpost-50709-0-97100600-1375789729_thumb.jpgpost-50709-0-74521700-1375789806_thumb.jpgpost-50709-0-54391000-1375789985_thumb.jpgpost-50709-0-56943300-1375790026_thumb.jpgpost-50709-0-70582500-1375790039_thumb.jpgpost-50709-0-07135200-1375790053_thumb.jpgpost-50709-0-21174600-1375790067_thumb.jpgpost-50709-0-97678000-1375790102_thumb.jpgpost-50709-0-52597200-1375790140_thumb.jpgpost-50709-0-19187000-1375790173_thumb.jpgpost-50709-0-88342900-1375790209_thumb.jpg
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
