Loaded with rb25det basemap ready for tuning. Needs a new loom from Adaptronic au store ($60) purchaced with grand plans but selling the 33 instead! Open to any reasonable offers.
Comes with usb programming / data logging lead.
https://www.sau.com.au/forums/topic/429948-adaptronic-e240c-ecu-for-sale/
