Hi Everyone,
Its that time again and I need to clear out all the parts that I don't require anymore. The reason for the sale is that I have upgraded to full adjustable suspension and the left over motor bits are not required with the RB26/30 setup. All parts were all still functioning when the motors were removed and have all been stored in the garage and now I need the room. Parts are all used and still in great condition. Im located in Adelaide, SA and can ship goods to buyer at his/her expense. All parts are out of a series 1 GTR and GTSt R33!
- oil cooler $30
- air regulator $30
- GTST diff centre $150 (no ring gear)
- generic 12' thermo fan $60
- HICAS steering unit with tie rods $100
- upper camber arms from GTST $20 each
- GTST disc brakes and calipers $ 250 (front and rear)
- gtst intake pipe $10 both turbo intake pipes
- GTR O2 sensors (3) $10 the lot
- vacuum/ water lines $10 (2 sets)GTR
- vac ballast tube $20 GTR
- Blitz blow off valve $70
- trust pod filter $40
- green label air flow meter $40
- rear main crank seal $10
- GTR crank scraper (both) $10
- GTR water pump (no cavitation) $20
- gtst washer bottle $20
- gtst rear camber arms $10 each
- gtst rear traction rods $10 each
- gtst clutch fan $20
- gtst castor rods $20 each
- gtst front LCA'S $30 each
- gtst rear LCA'S $30 EACH
- GTR turbo oil and water line $10
- Gtst full exhaust (mild steel) $100
- gtst A/c lines and condenser $50
- gtst s1 centre grille $80
- bosch 464 fuel pump $10
- gtr thermostats 76.5 deg $5 each (2)
- s1 gtst manual gear set (minus centre plate) $400
- gtst fuel tank $50
- gtst fuel pump assembly $60
buyer to pay for postage of goods!
PICS UP SOON :)
Cheers HULI
FOR ALL THOSE PEOPLE ASKING THE BRAKES ARE IN EXCELLENT CONDITION AND WERE ONLY REPLACED WITH NEW 8 POT AND 6 POT CALLIPERS AND ROTORS.
THE STOCK CALLIPERS AND ROTORS COME WITH THE BRAKE PADS THAT WERE ON THERE AND THE ROTOR THICKNESSES FOR THE FRONT ARE 29.5MM AND THE REARS ARE 19MM.
HOPEFULLY CLEARS UP ANY QUESTIONS
MIGHT EVEN SEPARATE THE SET IF NEEDED!
FRONT LCA'S ****SOLD PENDING PAYMENT****
VACUUM/WATER LINES (1 SET) ****SOLD PENDING PAYMENT****
CLUTCH FAN ****SOLD PENDING PAYMENT****
GTR TURBO OIL AND WATER LINE ****SOLD PENDING PAYMENT****
LOTS OF OTHER EXCELLENT PARTS STILL UP FOR GRABS!
All reasonable offers will be considered on any of the parts above.
LOW BALLERS WILL GET NO RESPONSE AT ALL!
LOTS OF GREAT STUFF STILL AVAILABLE!!!!
PM ON HERE OR MSG/CALL 0400262578
FORGOT TO MENTION THAT I HAVE SET OF GTR DUMP PIPES(WITH HEAT SHIELDS) AND ONE SPARE (WITHOUT) $15 EACH. PUT THE PIC UP BUT NO PRICE OR DESCRIPTION :(
LOTS OF PEOPLE MSGING BUT NO TAKERS. ALL QUALITY USED PARTS!!!
REASONABLE OFFERS ARE WELCOME. AT THESE PRICES THEIR PRETTY MUCH A STEL ANYWAY.
P&H IS BUYERS EXPENSE.
CHEERS HULI
offers are welcome people. all suspension arms $10 each
callipers and rotors $150
need the space, so want all this stuff gone and soon!
CHEERS HULI
help clear out these quality parts. None of the parts has ever been involved in any accident or mistreated. It was all functioning perfectly when removed and replaced by new parts. Need the room in the shed to finish off the car.
CHEAPEST PRICES I HAVE SEEN THESE PARTS ON THIS FORUM..
OFFER ARE WELCOME. SHOOT ME A PM ON HERE OR CALL/MSG ME ON 0400262578
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
