Mugabetown - Whoretownin' At It's Worst.
1 is too many
You used to be cool...
This! Also I am now the proud owner of a less than mint condition silver au falcon 6cyl auto :P
You were never cool.
Only thing they are good for is room and highway cruising
Skids! Auto falcons are most excellent at skids.
Yeah, if I owned that POS I wouldn't want to drive it either...
Oh I am so keen to throw scissors at you.... So keen. And then giggle my ass off all the way around the first corners of qr at 80ks an hour
I bet $20 that the wedge hammers nicks abomination around qr - again.
6 months from now ill bet anyone 50 bucks I blow the absolute doors off martins glorified door stop down the main straight of qr
6 months from now ill bet anyone 50 bucks I blow the absolute doors of martins glorified door stop down the main straight of qr
I did say "around qr." it's ok, the ant eater will be ready by then. :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
