Mugabetown - Whoretownin' At It's Worst.
Nice Scottie.
Mum told me it was a scorcher the other day something like 45deg?!
Yesterday it was like 40deg. Very warm. So warm i read reports the roads at Kilcoy were melting. No joke
I now pronounce you Chef Nastro, due to your cooking abilities yesterday
Haha, yer was bad man I was so f**ked off. But once the box cooled down all was good again... It was just way to hot of a day to be doing silly things.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
