Mugabetown - Whoretownin' At It's Worst.
Morning Michelle. What are the plans for today?
Putting headlights back in the broad minded person and then washing/vacuuming it then housework then gym then relaxing before tomorrow.
Waiting for shirts to dry whilst going to the bank and bottle shop.
Get home.
Iron dry shirt
Put tux on.
Head to wedding.
Get drunk
Hit in bridesmaids.
Come home.
Get home.
Iron dry shirt
Put tux on.
Head to wedding.
Get drunk
Hit in bridesmaids.
Come home.
So hungover Tony will be hungover for the cruise?
Get home.
Iron dry shirt
Put tux on.
Head to wedding.
Get drunk
Hit in bridesmaids.
Come home.
don't forget my SAU shirt while your at it.
Morning all
Yeah. Gonna go to parents house and get Emelie to do some chocolate Easter egg hunting and have lunch there
Also been putting on bonnet garnish on GTR last night
Still got Sikaflex on my fingers
How did the headlights come up?
Headlights came up amazing considering what they were, not perfect but you can't expect too much.
I don't think much on th 32 GTR bonnet garnishes.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
