Mugabetown - Whoretownin' At It's Worst.
Probley true about leaving it at the bottle shop but I have half a bottle of jw double black that needs to be drank and I duno tastes better on ice
Probably because it's blended shit.
All walkers are blends, you should be able to buy like sample bottles of expensive scotches so you can tell if you like them
And be extension all walkers are shit...the only acceptable walker is the King George the 5th bottle.
What! No Ice... I like ice
all good dude. It's mostly up to your taste, and ice can help tone the harshness of some whiskies
Mike however, understands the reasons you don't add ice to quality SM Whisky
It's not a quality single malt lol
I have blends around a lot as drink of choice is a rusty nail ie drambuie,blended scotch and a couple drops of lemon over ice, f**king delicious
I will try this someday - and I'm pretty certain that my thoughts will be something like this
'Tastes like JW blue label'
Tastes like a nice smooth Blue Label, thats the best way to describe it.
Yes well like I said I'm not going to drop $100+ on something I don't know if I like the taste of
My mates and I have dropped about $5,000 on scotches. Anything in the higher price range usually tastes nice.
Well what's a scotch in the 100-200 dollar price range that's worth drinking
What sort of flavours do you like? I'm quite partial to the Glenfiddich range ans am yet to find a bad one.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
