Hi guys,
Lately (in the past month), my car has been having a bit of struggles starting, at first it was struggling to kick over, I immediately thought my battery, which I replaced with a mates used one, temporarily fixing the problem, only to be coming back slowly. Last week I was out, I tried to start the car and it was turning over VERY slowly, waited literally 3-4 seconds, tried again, and started, wtf?
Not only that, my battery voltage reading is 14.2v when running (alternator is charging), usually dropping down to 9.0v when cranking over (as normal).
Also I believe my A/C compressor is having problems, weird whistling sound when it does start and tones down fairly quickly. Also hear a similar sound when I turn the A/C on.
Tonight, prior to going out, the car started, with a LITTLE bit of struggle. Then when I tried to start it later on, NOTHING, no crank, no clicking, nothing at all. I had to clutch start it.
When I got home I started diagnosing, I get reds, reading solid 12.0v on the meter, strangely enough though, only drops down to 11.2v when I go to crank it, the cat sensor light comes on, but that's also normal. Checked a few fuses, they seemed fine. Tried jump starting it, still gives me nothing. Jacked up the front end, it's on stands now, only had a very brief look-around at the starter motor, there doesn't appear to be any moisture, and all cables are plugged in.
Any thoughts?
I strongly believe it is something electronic, as I'd get SOME response from the starter if it was effd. Relay? Wiring? Should I start taking apart the dash and shit? Could the starter be shorted out somehow? Dust build-up? I don't know. :/
Really appreciate the help, if you have ANY information at all, please reply!
https://www.sau.com.au/forums/topic/431317-r33-suddenly-not-starting/
Not to sure if there the same, i can have a look at work on the Nissan catalog.
Try depressing the clutch pedal when you start your car (make sure your in neutral) and the load off the crankshaft will help start the car faster. Almost all new cars use this feature, you cant start the car without the clutch pedal fully depressed.
That should let you know if your starter is weak
Will give it a go, I tried starting it again yesterday and it was really struggling to kick over and very slow.
Spark plugs COULD cause rough starting, because if they are old/crappy then think about it, what starts the car? The spark plugs (ok, along with other parts but bear with me) - they give the ignition. When mine were crapped out, it sounded like my car was dying, it would crank slowly/roughly/coughing and then MAYBE start...after a few goes. crapped out spark plugs = bad spark = slow/crappy crank.
My starter motor started squealing to high heaven a few years ago. When I took it apart it was chock full of clutch dust (probably when the old clutch couldn't handle the turbo) gave it a clean up and lubricated and good as new.
It is a prick to get to but it's only 2 bolts to remove and I'd suggest taking it off for piece of mind, could be alot of dust not allowing the cog to spin fast enough.
I tested mine by hooking the starter up to a 12v battery on my bench so I could watch the cog engage up and down the shaft smoothly and check it spins freely.
The only thing that interesting is the lack of cranking or clicking... any wires from ignition or ecu that you think might be loose?
This should help with the starter motor :)
http://www.skylinesaustralia.com/forums/topic/333872-fixing-starter-motor-squeal/?hl=%2Bstarter+%2Bmotor#entry6445074
I see, I'll give it a go tonight, what should I use to lubricate it?
could be brushes are worn. split the starter motor apart, and check make sure brushes have good contact/tension to armature, and while your there give the armature a good clean using very fine sand paper
make sure u dont lose ball bearing when taking starter motor apart :P
Almost got it all apart, where should the ball bearing be? Because when I took out the core, the ball bearing was stuck to the inner side wall :/
I will post results when it's all back in :D
So I done as posted above, except I couldn't open up the solenoid to release the fork and actually open the entire thing up, instead I WD40'd the shit out of everything and blew it out with air, thick black gunk was coming out (WD40 infused clutch dust). Lightly sanded the commutator fins with 1500grit as they were fairly black (no contact = no good), so they were nice and gold. I also noticed one of those fins was half missing/damaged, but there's 30 odd of the them so it should be fine.
Stuck it all back in, and started like brand new. A very strong kick with no whistling sounds, or any odd sounds for that matter.
I greatly appreciate everyone's help on this one :)
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
