Blitz SBC i-Color Twin Solenoid (Spec-R) RRP$1000+
First checkout the link below for proof I'm an ebay POWER SELLER and can be trusted to post items:
http://feedback.ebay.com.au/ws/eBayISAPI.dll?ViewFeedback2&userid=iphone.addiction&ftab=FeedbackAsSeller
Check out the links below for full details:
http://www.nengun.com/blitz/sbc-i-color
http://www.blitzpowerusa.com/products/sbcicolor/sbcicolor.html
Had very little use.
$650
Pick up from Wyndham Vale VIC & sometimes Dover Heights NSW
Postage with Tracking = $20 or with Signature $23
Contact Brett
[email protected]
  • 3 weeks later...
  • 4 months later...
