I was told yesterday it was running really rich an can't change that till it's tuned but better than lean ?
But they were talking to a Nissan moron ,now I know how other people have felt when I'm going on at a mile a minute on other topics.
Larger turbo on stock ECU will run rich
To protect the engine.
No chance of getting 280kw with just a computer.
As zebra said, chances are that it's got stock injectors, fuel pump and AFM because its the stock computer.
So max with those parts and a tune is around 210-220 but with a larger turbo its going to be a laggy 210-220 I would guess.
So start planning what you want and we can help try come up with what you will need.
The mechanic I seen yesterday said he'd have it running 280kw in a week, but what we spoke about the haltech platinum piggyback I'd have a safe 220-230 but your right about injectors , regulator and pump.
Are I tank fuel pumps a hassle to install?
I'm about to run an injector cleaner through a full tank but still have to find out about the fuel system
Thx
Have a good look at you injectors and compare with photos on google images.
If your keen, take out the fuel pump and do the same.
If you spend a bit of time reading : http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
You will see what is actually needed to make power, and what does nothing.
What i learned is if you have a bigger turbo and want more power, you need more fuel. The standard fuel system only has enough for a slightly bigger turbo, and small power gain.
And you need a computer to run it of course. A Nistune is suitable for anything thats not making heaps of power. ( for rb 25s i dont know exactly how much )
Almost anything else you do to the motor wont give more power, like wanky bov's etc. But things like an upgraded cooling system can keep it in good nik longer.
Dont forget the cheap effective things like exhaust and intake, though you may have most of that done already.
Personally id make it run nice with the turbo you have, and concentrate on handling.
Theres a lot of bits and pieces to make it handle good. It can eat up a lot of cash.
I couldnt use all my 180kw because my diff was stuffed, no point having power you cant use.
Ps: im jealous of your wastegate actuator, thats nice and simple, reliable and adjustable.
Edited by D.I.Y. Mik
fuel regulator usually isnt needed as upgraded injectors dont need more pressure.
unless your going for huge power
How can the mechanic say 280kw without knowing what its got.
Not being a flamin mongrel.
Trying to help.
Haltech piggyback is the most ridiculous thing ive heard.
This isn't 1999 anymore.
Nistune will do everything you need for half the price and as a bonus will actually work.
Car wouldn't run with bigger injectors.
If they are purple they are stock.
Ok.
So what you want is.
And this depends on budget too.
Nistune or a powerfc.
550cc or larger injectors.
Larger fuel pump. Walbro or something similar
Z32 MAF
Metal intake pipe
Then better than stock clutch (im partial to os giken)
Then tune by someone who knows what they are doing...once again my preference to take it to yavus at unigroup engineering in sydney (I wont ever take my car anywhere in canberra, but im a fussy prick) others are happy with a couple of the locals.
There arent many highflows that will do 280rwkws on 98 so expect 240-250 at the most.
Now you have a quick car that needs to stop and steer better. So factor in good suspension stuff. A good diff Centre and work on the brakes. New rotors and good pads are enough for most.
Ok.
Z32 MAF
Metal intake pipe
:yes: exactly
Just found out the guy I brought the skyline off in apr cashed in the rego 2 days after I did the revs check an I've got to re rego it , have to either replace the steering rack or stop the leak.
3 new tyres and kill 6Db, also raise the adjustable coil overs they do hight but can I do it or do I have to get pedders or such too, same principle as a motorbike shock I think but I want the adjustment to be exact.
Also thought about adjusting the boost with the adjustable rod but don't know what distance to boost it will make.
That's where I'm at.
Also looking for a maf befote tune.
Cheers
Oh also found out they wound back the tacho it's got about 300000 not 169000 as it read , is anyone honest anymore
But compression check an engine check is healthy so don't know what to think
I will never do biz in vic again. That's 3 times now I've been screwed down there .
Be careful not only in Vic but every other state. Normalllllly - SAU people are fair honest - as we are a little tight knit community. I purchased Rosie from vic (SAU seller) and it was quite a good deal. Nothing wrong with it and all in good nick - all I could ask for was a little less lazier seller :P
cheers
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
