This car has been my pride and joy the past 2 years. I have looked after this car, oil changed every 5000km. Previous owner did ground up build, respray and inspected all parts before reassembling. This car is in great condition.
Has had a full respray in Mazda colour silver, and some seam welding has been done on the underside before being sprayed.
Suspension:
Most of this stuff was done when it was resprayed.
D2 Coilovers
Adjustable Camber Arms Front and Rear
New wheel bearings
All new Urethane Bushes replaced throughout
New Ball Joints
Rebuilt CVs
Supension Arms removed and Powder coated
Varostoen 19in Wheels in Matte Black (TE37 Lookalike)
Kumho KU19's all round
Brakes:
DBA 2500 Rotors on front
Stainless Steel Braided Brake lines
QFM A1RM Pads Front and Rear - These are quite noisy, my next pair would be a little more street orientated. They have great bite but can be quite noisy when used lightly.
Motul RBF 600 Brake Fluid
Diff was fitted with Nismo clutch packs and re-shimmed at Award Diff/Gearbox with recipts. R32 GTR Diff's are 1.5 way LSDs.
The front diff had an oil change when doing the CV joints.
Engine:
New Front Main Seal
New Gates Racing Timing Belt
New Clutch Fan
New engine bay seal
New headlight protector seal
New HKS Metal inlet gaskets
New heater hoses under inlet manifold
Splitfire Coilpacks
Nismo Twin Plate clutch
New Coil Pack loom
Relocated oil filter, with oil Cooler
Moroso 3quart Accusump mounted in boot
Earls Stainless Braided -10 lines on Oil Cooler and Accusump
Penrite HPR 5w-40 Synthetic
Oil systems takes roughly 7L
Interior:
GTR Seatcovers
Sony AUX Headunit
Momo Steering wheel
Jaycar 5" speakers in the rear
Mongoose Alarm fitted at Carbon Car Systems
I have a large folder full of recipts for money I and the previous owner have poured into this car over the years. The Air Conditioning has been a project on this car, It works but the gas leaked out. I found a large leak out the back of the compressor, so a 2nd hand one has been fitted, and the system is filled with nitrogen ready to be re-gassed. Depending on how quick it sells will depend on weather i get this fixed first or not.
It will be sad to see it go, but i don't see the point when i don't use it enough. Am happy to answer any questions about the car.
I also have an RTA History check that i paid for when buying the car.
This car is mildly stock, as i never could commit the funds to going all out on an engine build/turbos etc. It has a few things i've probably missed but come and inspect for yourself. Have tried to upload as many photos as possible so you can get the best idea about how it is. As you may be able to tell i'm no photographer! Couple in different lighting, all were taken the same day.
Inspections welcome.
Call Aaron on 0412 508 903. Located in Dundas Valley.
post-93127-0-81206800-1381049437_thumb.jpgpost-93127-0-08088800-1381049459_thumb.jpgpost-93127-0-05157400-1381049479_thumb.jpgpost-93127-0-46925400-1381049494_thumb.jpgpost-93127-0-11503500-1381049512_thumb.jpgpost-93127-0-97251800-1381049528_thumb.jpgpost-93127-0-05092700-1381049552_thumb.jpgpost-93127-0-77384200-1381049656_thumb.jpgpost-93127-0-08773500-1381049667_thumb.jpg
https://www.sau.com.au/forums/topic/432923-syd-1992-r32-gtr-21000/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
