RB20 wastegate actuator $75 - Holds more boost than the standard R33 actuator but still within what the standard ECU can handle, roughly 10-11 PSI depending on your intake/exhaust setup. Fits stock turbos (including OP6 rear housing) and Highflows.
Engine mounts (pair) $120 - Fits non-hicas R33. I bought the wrong ones, these are brand new. They also fit S13/S14 180/200SX according to the packet. not sure if thats on the standard motor or with an RB25. Inspections welcomed
JJR silicone intake $20 - used as an interim part. Trimmed for stock airbox. Useful to get you out of trouble or for stock applications, I wouldn't use it if you're running any more than about 12-14psi though.
Series 2 AFM and Plug $75. Can be wired in as an upgrade to the S1 AFM. If you have a Series 1 I can install it for you its simple enough. Selling as I'm running Z32 with nistune.
"DRIFT" brand adjustable Blow off Valve, adapter bracket and genuine nissan gasket. $50, Came off my R33. Please note this is not a road legal blow off valve as it vents to atmosphere.
Standard S1 ecu. Not sure what these are worth? Asking $80
Single DIN tray with door. Not sure if this is a standard nissan part or whatever. $20
ALL PRICES ARE NEGOTIABLE. PM for my phone number, Will reply within the hour
Edited by Blackkers
I've also got a clutch fan for an RB25. Just the fanblades no clutch assembly. 2 cracks along the center but its suitable for anyone who isn't drifting i guess. $20
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
