Hey guys just have a couple parts left over
Item: OS Giken cam gears to suit Rb25/26
Condition: Used but in new condition
Price: $250
Item: Apexi pod filter intake kit (includes pod, adaptor, gaskit, all bolts etc)
Condition: New
Price $70
Item: Apexi EL2 gauge
Condition: New but has been taken out of the box
Price: $60
Located in northern suburbs of Melbourne and travel to the city often
Contact me on 0423741630 - Shannon
