I have lived in Gladstone my entire life, cops are not normally an issue but in saying that I haven't really driven anything that has looked that modified. We have only really had one "defect station" that was just some cops set up at the waterfront pulling everyone over but they didn't pop bonnets or get any of the people running illegal HID's, they weren't even worried about my exhaust and HFC's that I just got put on earlier that day. Beneraby raceway (drags) is the only motorsport event for cars that aren't 4wd's around here though. Me and some mates get together a bit with a few imports/non commodore/falcons (S13, Supra,370z, 86 etc etc) but they aren't exactly meets just some lads hanging out.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
