Hey guys, I really don't post a lot, because I'd rather search. 9/10 times your question has been answered somewhere on the forums. Lately all my questions I've had been directing me to this site.
So I though I'd join!
A little about me, I'm originally from the states, I'm currently out here in Okinawa, Japan. If you get the chance..goto mainland Japan!
I've owned a handful of cars and trucks. First car was a 240sx, came out here to Japan and bought a skyline to scratch off my to own list. Also purchased a FD3S, turbos took a dump on me and now I an Onevia.
It had a red top and I'm currently swapping a RB with a nice amount of upgrades done to it. Only reason I considered the swap...the RB was free :) from a friend for a "baby present".
Anyways how's it going?
https://www.sau.com.au/forums/topic/433491-hello-from-okinawa/
Hi,
I am in Tokyo. I often get to hear, including today actually, about how great Okinawa is. Unfortunately I have not been off of Honshu though.
Sad news about the RX7, would have made a great base for an LS1 swap though, still got the car?
Are you in the Marines? Mind if I ask what sort of work you do?
Okinawa is Great. I was there for a couple of months for work once.
If on holiday, the northern parts of the island is much prettier, and far more holiday friendly than the Naha end. Go and see the aquarium, it's amazing.
