ok i've finally got all my money of those government bastards and i keep getting told i need the power fc not the safc, but seriously i know alot of high hp cars getting arounf with safc's!!! so at what point is the powerfc the better option? i am running a hybrid t3/4 turbo am thinking prolly forged heads and deff a bigger pump so i can run more than the 10psi i can now but wouldnt wanna go much more than 16-8 psi and would be happy with 300-350rwhp....
so what do yaz reckonz ay?
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/
Neither - go Microtech :P
someones selling one here: http://forums.skylinesdownunder.co.nz/show...&threadid=18058
Reason for this is, if you're trying to push out those figures you'll need to change a few other sensors, and at 350rwp you'll need to either upgrade to a z32 afm, or go for a diff ecu, such as the microtech which runs on it's own internal MAP sensor
Power fc is just a drop in replacement, so runs off of the std factory sensors. Allows big tuning but the sensors are still the same and will need to be upgraded
s-afc is only an AFM interceptor, it adds or subracts a small amount of voltage and tells the factoy ecu this, so that you can tune the mixture a little at each load point
I'm pretty sure that you can't put a MAP sensor or anything else, to by-pass the AFM, since it is requiring an AFM signal, and the two aren't in a proportional relationship (ie - not compatible)
otherwise you could run a haltech or microtech in piggyback with the factory ecu, so that you have the new ecu controlling fuelling and spark and the factory ecu controls the idle and air con etc - if cops look in kick panel it shows std ecu, but factory ecu only controlling the basics
they're all good though, just depends on whichever one you want to have :)
also I think s-afc's are 512 bux from nengun, but can't be bothered looking as 56k dial up is pissing me off ;)
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-68743
but when using the s-afc you'll be losing kw's
the power fc can be tuned to a fine enough degree (per 500rpm I think...) and thus your power band will be more defined
the microtech I'm pretty sure is universal, and requires a couple of extra sensors (which don't cost much anyway) and a tune up
personally if I were you and you only wanted an apexi piece, then I'd go the power fc
and yep, injectors will need to be upgraded for sure, as well as a few other bits
but with pleasure (fast car :)) comes pain (expenses ;))
taka kaira's url is www.takakaira.co.jp
actually, hmm, doesn't work, maybe it's .com then
I don't know :P
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-68903
while we're all on the subject of S-AFC's....
does anyone know what a decent choice is for an S13 sr20det.? I don't want to use a full ecu replacement like a microtech/haltech etc..
so I'm looking at either a piggy back unichip, a S-AFC or getting my ecu re programmed. what ever I choose, I want it to be tunable for a larger AFM like a z32 unit. any suggestions.?
thanks.
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-68978
unichips are crap
nuff said :)
it depends on what you've done to your car osc@r, which should determine what you need
and whether you intend on doing anymore modding after the chip
if you are still doing other stuff, then reprogramming your existing ecu (someone correct me if I'm wrong) but that will only remain set to how it was when you had it reprogrammed. That is, if you do additional things to your car it will require retuning, and will cost another few hundred bux. But for up to 500 dollars for an s-afc (which can be tuned at any time) I'd say that that would be well worth it (if you don't want a whole new ecu)
sory if it doesn't make much sense, getting tired!! ;):D
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-69047
  • 4 weeks later...
Originally posted by skyzerr33
dude with those figures your after u need the pfc as you'll likely need new injectors and the safc want be able to use them to there max potential.
and 500-600 for a safc is abit much even for nengun
pay 540 tops from him or go to takakaria
Recently I was selliing them for $475 AUS Delivered.
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-80150
because ignition changes are expensive. eg remap = $500 per tuning session
SAFC's cost $100 for a re-tune. if youre continually modding your car then its unrealistic to keep paying out the large amounts for remaps etc when SAFCs (which may not be the final solution) can provide some tuneability. ignition tuning is also limited by our pump fuel compared to japans isnt it?
i plan on getting a remap once ive finished modifying, but for now the SAFC provides enough tuneability to keep the car runing relatively smoothly. shannon: if youre finished modifying, remap. if you plan on doing more than SAFC simply because its cheaper to re-tune once you modify further
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-80572
you know once you done the $500 chip.... it can easily be retuned at std tuning cost?
lets see remap $500 plus tune ignition and fuel
Vs
safc $400 plus tune only ever going to do fuel but has extremely sweet rice value blue screen
mmmm
https://www.sau.com.au/forums/topic/4335-safc-vs-p-fc/#findComment-80577
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
