During my constant perusal of the net for all things Jap, I came across this. I've mirrored the images on our server so as not to burden the owner's server with huge amounts of images.
Some good oldschool and really far out cars at this meet. Welcome to the world of Bosozoku.
This was a meet at Daikoku in Yokohama a couple of days after January 1st. To celebrate the new year, bosozoku (motorcycle hooligans) cruise into Kamakura on motorcycles via the Shonan (like our PCH) in droves. Their other favorite mode of transport is an unregistered Mark II or Cresta (our Cressida) with its roof chopped off... The weekend after January 1st, they gather at Daikoku (a well-known spot for meets) for a huge meet at a rest stop... This is where I snapped these pics. The cars ranged from bozo'd out old school Laurels/Crestas/Skylines to crazy vans and flashing trucks...
