NiSSAN SKYLINE R33 TURBO PARTOUT!!!!!
cleanest R33 body and panels are in perfect condition
rb25det s1 motor 132000ks with loom and ecu $1500
brake calipers $300 or can separate $200 fronts $100 rears
Mspec front bar damage on left gand corner $150
radiator $100
r33 gtst diff $200
half shafts $100
headlights in awesome condition $400 for both or $200ea
bonnet s2 $200
guards $100 ea
stock standard suspension $100
factory oem side skirts $150
factory oem rear pods $100
rear bar $100
3" exhaust from turbo back $300
standed exhaust $100
R33 factory wheels $150
r33 nismo clear indicators $50
Lsd diff $200
half shafts $100
rear skyline oem strut brace $100
rolling shell dead straight no dints or anything $600
for any other parts call or text me on 0432-062-780 located in Melbourne
https://www.sau.com.au/forums/topic/434526-nissan-skyline-r33-turbo-partout/
  • 2 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
