Hey guys did a pressure test on the intake and I have a blown plenum gasket :angry: the supplier I bought it off has a start up warranty on the motor the fact that this was already present has asked for a quote to fix and get the motor running. Lesson: warranty is awesome
Well hopefully those two fairly big issues are the only thing wrong the motor.
