C Pillar trims - hard to find 2nd hand ones not stuffed so be careful
JJR do sell them new for $140 a side. Expensive !!
when pulling them out/in it is good to remove the back of the back seat.
if you try to flex older ones they crack and new ones may also. careful clipping them in.
https://www.sau.com.au/forums/topic/435809-r32-gtr/#findComment-7129047
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
