As stated in the title I have a PowerFC Pro with hand controller to suit R32/33 rb26's.
Price: $1100
The difference with the pro model is that it uses an ignition cut rev limiter instead of fuel cut on normal pfc's (this is to help prevent knocking) and also it has a launch control system. The launch control works by allowing you to set a secondary, lower rev limiter that only kicks in when the car is stationary (eg 5000rpm). Then once youve moved over 0kph, it goes away allowing you to rev to the regular limiter (eg 8000rpm) so that you can get perfect launches every time. These ecu's are long discontinued and quite rare nowdays. It also comes with a hand controller.
Secondly are a pair of Nismo afm's.
Price: $500pr
The nismo afm's are the only bolt in upgrade for your standard afm's as they are the same size and hence fit into the standard intake piping (which means will also work with stock air box).
Items are only being removed as I will be upgrading to a Haltech ecu which also doesnt need afm's.
Both items are in Adelaide and can be shipped at buyers expense. I will sell the lot for $1500 delivered if someone wants all of it.
Contact via PM, Cheers.
https://www.sau.com.au/forums/topic/436090-sa-powerfc-pro-nismo-afms/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
