1996 Nissan Skyline GTS-T Series 2
Condition:
Mechanically sound, Body is average
Extra Info (ie mods/history etc etc):
Just passed pits 24DEC13 due to yellow for old oil stains on block, hicas delete bar(!) and pod filter.
Passed with everything as is including rims (rare)
Engine -
225xxx genuine kms
Original RB25 engine with 225xxx genuine kms (rare) (service and Mobil One 15w50 oil before track day 26DEC13)
Splitfire Coilpacks
Standard RB25 gearbox with Exedy HD Clutch (installed in 2011, 5000kms ago)
Apexi Pod Filter (w/ permit)
Front Mount Intercooler
3.5" Exhaust with dump pipe and cat (not offensively loud)
KKR480 china special (apparantly 450 hp if you believe it, internal wastegate sometimes doesn't fully close properly causing it to take AGES to hit boost! Just annoying because it doesn't always happen!! Sucks hard for drags but was prefect on the track)
Greddy Emanage Blue Piggy Back
Greedy E-01 Boost Controller with link cable and remote! (rare)
Suspension -
Upgraded koni inserts and unknown springs (firm but not too bad)
Hicas Delete Bar
Nismo Front Strut Tower Bar
Full Suspension alignment 22DEC13
Brakes -
Standard sumitomo 4 pot fronts and 2 pot rears
Standard size rotors (good condition)
New Bendix Super Premium Pads (one track day old)
Fluid Replaced and Bleed with High Temp Super Dot 4
Wheels -
18" Nissan V35/36 rims with new Federal 595 SS 235/40/18 all round
No rubbing on track or at full lock.
Rims are in OK condition, have some marks and scratched in places.
Body -
Recent Partial Respray in original KH3 black (without clear coat at this stage).
It is an acrylic paint so it is matt black in appearance.
Respray due to sun damage from QLD and WA sun!
NOTE: I only painted the bonnet, roof, window pillar, boot lid, spoiler and rear bumper
Doors, front and rear quarters and front bumper are standard.
Sides have the usual carpark marks and front right quarter is dented.
I was going to remove all this before painting the rest.
This is the only major area that lets the car down.
Currently running 12psi daily and 15psi for track work.
No dyno time but at Racewars I kept up with a 350hp R33.
So i'll estimate low and say it has around 320hp.
I took it to barbs on and managed a 1.06 on the short track, if that helps at all.
I do suck at track work though. Still learning... :/
$7000 NEGOTIABLE OR SWAP
Contact Details:
0498 466 498
Michael
Scarborough, Perth WA
Delivery & Conditions of Delivery:
You pay moneys, you receive car.
Cash or bank cheque is acceptable.
Looking to sell to UPGRADE my car.
I will only consider swaps for a BETTER car with cash your way (obviously)
I'm open to swaps with cars standard or built.
Must have at least 250+ hp and track capable! (very important)
Currently looking for a built 32/33 GTR, 02 STI or maybe EVO.
Looking to spend around $20000 max
http://www.gumtree.com.au/s-ad/scarborough/cars-vans-utes/1996-nissan-skyline-gts-t-series-2/1035138399
Thanks for looking! :0
Edited by intercpt
Just found the GTR i want to buy!
I'm motivated to sell hit me up with your best cash offer and i'll deal.
Might be negotiating a swap with cash their way so looking for offers over $4000.
Strictly no lowballs.
Worst thing I can say is no.
Cheers,
Michael
Edited by intercpt
Just so you know this is my current daily/track car.
To be honest it is not the most economical daily.
Gets 500km per tank open road driving, but kick the guts in it and bye bye fuel!
I used half a tank after 12 laps of barbs total!
The wastegate issue is extremely minor due to the bad design of a china internal wastegate.
I was going to remove turbo, weld gate shut, clean up the weld and run matching china spec external.
External wastegate is ideal for the car enthusiast! haha
Run standard boost
Daily
Run 15psi
Track it
Run standard boost
Drive it home
Profit
Edited by intercpt
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
