Yeap very entertaining considering I do not watch any sport that is not ice hockey or lacrosse.
Still that little guy needs to work on his ball handling skills, dropped bomb, then let it roll through legs, was quite funny!
Although I really should not make snide comments like that, put in the same position I would probably run screaming off to my mummy if I had some of those blokes chasing after me, yes I am a coward AND PROUD!
But how good was Price, a couple of his line breaks were great, Sing had a couple great runs, overall both teams played excellently, gotta love big willy, geeze he is a big bloke, and that other big dude who just kept running, awesome, but yet again as it has been already stated, Slater, what a try, everything just fell into place, was awesome to watch!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
