I am after $19,999 and price is negotiable, no low ballers/time wasters/scammers who work on oil rigs.
I've had this car just less than 2 years and it's been a pleasure to own and drive.
purchased at 97,000km and currently has under 122,000km. I am the second Owner in Australia.
I have done the 100,000km timing belt maintenance consisting of OEM and aftermarket parts that include Timing belt, all Auxillery drive belts, tensioner & idler bearings, water pump, rocker cover seals, spark plug seals, oil cap seals, new spark plugs, replaced all fluids including radiator, front+rear diffs, Transfer case, gearbox oil, AYC fluid and power steering fluid with fully synthetic oils from Penrite, AYC flushed with Mitsubishi OEM fluid.
Always serviced with Penrite racing Tenth 10w-40 Engine oil with Geniune mitsubishi oil filter every 5000KM & driveline fluids replaced every 20,000KM.
The car is engineered for the exhaust and intake and I have paperwork and majority of receipts for purchases and work done to the car. I still have japanese log book, and user manual.
It has been tuned to 209awkw on 98RON, has a secondary map for E85 but would recommend a tuner to fully tune it if you want to run E85, also recommend to change to 1000cc + injectors.
Current mods on the car include:
- EVO 8 MR 10.5T turbo
- ported stock manifold
- 3" stainless steel turbo back exhaust (o2 and down pipe unknown brand from Japan when imported), catback is HKS silent power with hot dog resonator fitted
- straight through race cat (will include spare 3" cat)
- HKS 264/272 step 1 cams
- 3 port Grimspeed boost controller
- HKS air filter
- Walbro 255 in-tank fuel pump
- AGP LICP
- Meek turbo Outlet
- Slotted front & rear brake rotors with high performance street pads from X3E - <700km old brakes bled and filled with high performance Motul RBF600 Brake fluid
- Competition Clutch Stage 2 + ACT Monoloc to help prevent thrust bearing from popping out
- Energy Suspension shifter base bushings
- Koni 2 way adjustible (damper & rebound) shocks + custom 10kg king springs (shocks rebuilt just over 12 months ago), sits 25mm lower
- whiteline 24mm adjustible rear sway bar
- Varis carbon exhaust shroud
- carbon eye lids
- 20% tinted windows
- tinted rear window visor
- vortex generator
- shorty antenna
- 4300K HID's + white LED parkers
- 17x8 +35 ROH Envy wheels, painted satin black with Nitto NT555 235/45/17 tyres, (less than 10,000km old) + sexy red lug nuts that give extra 20kw. running 15mm bolt on hub centric ichiba spacers on the front.
- brake calipers have been refreshed with red caliper paint and stickers
- Clarion DVD entertainment system
- custom moulded sub and amp enclosure in boot
- upgraded front + rear speakers
- amp powering speakers under driver seat
> unsure of amp/speaker specs but will get them soon.
- White LED interior lights
- greddy shift knob
- Tephra V7 mod - dual map tune (98 & e85 - e85 is base map only on standard injectors and current mods), has features setup such as launch control, NLTS, valet mode + more can be setup.
- Innovate motorsports LC-1 wideband gauge
- autometer colbalt boost gauge
- autometer dual gauge holder mounted on steering column
- HKS turbo timer
the bad:
- got reversed into in a parking lot and dented the front bar along with some paint damage - quoted $250 to fix at Intense Paint & Panel, Warwick Farm
- scrapes on underside of front bar
- small rock chip on front lip/ front bar.
Apart from the above, the car is still in good condition, i detail it every few months, and will be detailed before sold. Headlights have been polished and sealed with meguiars UV protectant.
Interior has been steam cleaned and seats are in good condition, no rips or tears.
Car is located in Gladesville NSW - Monday to Friday before 6pm
and Liverpool, NSW - after 7pm
Please email me if you have further questions. Sorry but i am unable to upload new pics this stage, pic below is prior to brakes repaint & rear window visor being fitted.
Will consider swaps for 2008+ V36 Sedan Type SP, and may consider swaps + cash my way for an 05-06 Ninja ZX6-R.
contact me for more infromation.
  • 2 months later...
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
