R31 drift pig Posted January 20, 2014 Share Posted January 20, 2014 (edited) Looking to sell my 1994 R33 Type M Skyline. Bought the car just over 12 months ago completley stock bar a set of 17's and blown coilovers. I've added everything in the last 12 months, so all parts have very minimal use on them. Majority have less then 5000kms. I have almost all receipts for what ive bought and what work ive had done, and it's many thousands of dollars, more than the asking price. I'll get the bad points out of the way first... Both front fenders are munted. Previous owner rolled them REALLY badly, and the D/S has a couple of dents. Has a couple of carpark scratches and dents. Roof, bonnet and top of rear bumper have clear coat fade, but polish up ok. However does require respray to fix. It's all cosmetic issues, which was all I had left to finish, once the mechanicals/driveline had been sorted. Get a pair of 25mm FRP front fenders and have the car blown over in the factory colour and it's done. Was quoted between $1000 - $1200 for a decent closed door spray in OEM black, you could spend more for a REALLY good job, or if you know someone who can do it you're golden Now the good stuff... Car is religiously maintained, using only the best gear (Nulon oil, redline gearbox and diff oil, ryco filters, Caltex 98 octane fuel) and also upgraded with the best parts money can buy. All work not done by myself has been performed by Shaun @ Boostworx, and he can also be contacted in regards to the car. Also in the last 12 months ive replaced timing belt, cam seals, water pump, tie rod ends, lower control arm and knuckle bushes, all the belts, and had air con fully serviced and regassed. Car also has a Viper 2 way paging remote alarm with remote start. It's a perfect streeter, absolute weapon to drive, hit 3500 rpm and its all over the street, but super easy to commute in day to day traffic., it's just become impractical for me to keep, and have other projects on the go that I would rather finish. Body Type M Front bar/sideskirts/pods/wing, 8000K HID kit Interior Bride Digo-R seats in black/gradation on bride rails (Both Genuine with receipts) Nardi Classic Steering wheel/Sparco Detachable hub kit/Yashio Factory shift knob HKS Boost/oil temp/oil pressure gauges in Border Gauge pod, Yashio Factory Water temp Meter (To be installed) Kenwood Head Unit/Splits Engine / driveline Rebuilt RB25 motor - CP Pistons/ARP Hardware/Greddy Metal Head Gasket - Full reciepts for engine build - over $10K worth. APEXi Pod Filter/ Z32 AFM/Stainless inlet pipe (Have another intake pipe with no connection for emissions) Trust TD06SL2-20G 10cm turbo/GReddy High-mount Stainless Manifold/Tial MV44 Wastegate/Braided oil and water lines Plazmaman FMIC And piping 1 piece dump/front/APEXi 3 inch exhaust (Not too loud, good on the street) Nismo fuel pump/Nismo 550cc injectors APEXi Power FC ECU tuned by Shaun @ Boostworx - 270rwkw @ 19psi with dyno sheets. More in it with a decat pipe and some cams. Nismo GMAX twin plate clutch/Braided clutch line/urethane gearbox mount/Nismo pivot ball Nismo 2 way LSD, alloy diff mounts Alloy radiator/Silicone Hoses/Nismo Thermostat/N1 water pump HKS oil cooler kit with filter relocation Optima Dry Cell Battery Wheel and Tyres Enkei RPF1 wheels in silver, 18x9.5 -5 and 18x10.5 +10 215/40 and 235/40 Tyres Suspension setup - FRONT Cusco Comp S coilovers – 10kg Cusco Adj. Upper arms Cusco Adj. tension Rods Nismo Tower Bar w/master cyl. brace Suspesion setup - REAR Cusco Comp S Coilovers – 8kg Cusco Rear upper arms with eccentric lockouts Cusco Cradle collars HICAS lock bar Im asking $13,000 negotiable upon inspection, car has current rego with just less than 3 months left. May consider trade for HSV/V8 Commodore as a daily Contact Ben on 0439 888 043, or [email protected] Edited January 20, 2014 by R31 drift pig Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/ Share on other sites More sharing options...
R31 drift pig Posted January 25, 2014 Author Share Posted January 25, 2014 Price is negotiable. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7180253 Share on other sites More sharing options...
Joey83 Posted January 26, 2014 Share Posted January 26, 2014 What would be your best price you can do on it? Im interested and im from Melb so i wont need the reg or rwc and ill be paying cash, so if you can give me a really good price i will come and take it off your hands. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7180994 Share on other sites More sharing options...
R31 drift pig Posted January 26, 2014 Author Share Posted January 26, 2014 If you're really interested, give me a call and we can work something out. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7181068 Share on other sites More sharing options...
R31 drift pig Posted February 5, 2014 Author Share Posted February 5, 2014 Bump - still for sale. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7190112 Share on other sites More sharing options...
BLITZ-26 Posted February 9, 2014 Share Posted February 9, 2014 Did you do rods in the motor as well ? Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7194050 Share on other sites More sharing options...
R31 drift pig Posted February 9, 2014 Author Share Posted February 9, 2014 stock rods. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7194072 Share on other sites More sharing options...
BLITZ-26 Posted February 10, 2014 Share Posted February 10, 2014 Might give you a call about it, why didnt you do forged rods while it was getting built ? Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7195221 Share on other sites More sharing options...
R31 drift pig Posted February 11, 2014 Author Share Posted February 11, 2014 Give me a call if you're keen and have the $$$. Got a number of people interested but no-one's front the coin yet. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7196048 Share on other sites More sharing options...
champcarman Posted February 18, 2014 Share Posted February 18, 2014 Might have a look if you have not sold by Clipsal 500 weekend? Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7203338 Share on other sites More sharing options...
R31 drift pig Posted February 19, 2014 Author Share Posted February 19, 2014 No worries, im hoping it's not around then, but still plenty of interest but no-one has fronted any coin. Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7204828 Share on other sites More sharing options...
R31 drift pig Posted February 21, 2014 Author Share Posted February 21, 2014 and sold... Link to comment https://www.sau.com.au/forums/topic/437890-1994-r33-type-m-heavily-modded-awesome-streeter/#findComment-7206705 Share on other sites More sharing options...
